[Bio] / FigKernelScripts / check_consistency_of_sample.pl Repository:
Log of /FigKernelScripts/check_consistency_of_sample.pl
Sat Aug 29 22:06:29 2009 UTC (10 years, 5 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +9 -6 lines
correcting looping through parts of the genomes
Fri Jul 10 00:24:08 2009 UTC (10 years, 7 months ago) by overbeek
minor fixes
Fri Jul 10 00:19:56 2009 UTC (10 years, 7 months ago) by overbeek
Changes since 1.4: +3 -3 lines
bad bug
Thu Jul 9 22:11:35 2009 UTC (10 years, 7 months ago) by overbeek
Changes since 1.3: +7 -3 lines
make fabrics from all hits
Thu Jul 9 15:36:23 2009 UTC (10 years, 7 months ago) by overbeek
CVS Tags: rast_rel_2009_07_09
Changes since 1.2: +66 -61 lines
minor fixes
Thu Jul 9 12:44:53 2009 UTC (10 years, 7 months ago) by overbeek
minor fix to output
Thu Jun 11 19:35:46 2009 UTC (10 years, 8 months ago) by overbeek
basic metagenomic tools
