[Bio] / FigKernelScripts / changed_starts.pl Repository:
Log of /FigKernelScripts/changed_starts.pl
Links to rast_rel_2011_0119: (view) (download) (as text) (annotate)
Sat Aug 20 12:32:29 2005 UTC (14 years, 7 months ago) by overbeek
fixes to calling starts
Sat Aug 20 02:37:22 2005 UTC (14 years, 7 months ago) by overbeek
fixes to call_starts
Sun Aug 7 14:27:00 2005 UTC (14 years, 7 months ago) by overbeek
Changes since 1.3: +19 -6 lines
Wed Aug 3 22:57:30 2005 UTC (14 years, 7 months ago) by overbeek
Added EMACS "perl" tag. -- /gdp
Thu Jul 28 17:45:37 2005 UTC (14 years, 8 months ago) by overbeek
modifications to correcting starts code
Sat Jul 23 16:04:32 2005 UTC (14 years, 8 months ago) by overbeek
fixes to checking for starts in close strains
