[Bio] / FigKernelScripts / build_sas_distro_from_cvs.pl Repository:
Log of /FigKernelScripts/build_sas_distro_from_cvs.pl
Mon Jun 27 21:29:23 2011 UTC (8 years, 11 months ago) by olson
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +71 -3 lines
Revert to the versions from backups.
Mon Jun 27 21:08:09 2011 UTC (8 years, 11 months ago) by olson
CVS Tags: myrast_rel40
Revert to bob's latest versions.
Wed Jun 8 19:03:12 2011 UTC (8 years, 11 months ago) by devoid
Adding support for recursivly searching for sas components.
Neccesary for ModelSEED sas and dtr components.
Modified Files:
	build_dtr_distro.pl build_sas_distro.pl
Mon Sep 20 19:40:19 2010 UTC (9 years, 8 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.1: +21 -3 lines
mods for building myRAST
Fri Feb 12 20:16:52 2010 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
Support building SAS distribution from clean CVS export.
