[Bio] / FigKernelScripts / build_protein_families.pl Repository:
Log of /FigKernelScripts/build_protein_families.pl
Links to mgrast_rel_2008_1110: (view) (download) (as text) (annotate)
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Mon Nov 28 04:31:07 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.3: +25 -11 lines
updating protein families
Tue Oct 25 17:41:33 2005 UTC (14 years, 3 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.2: +22 -0 lines
more more more proteinfamily stuff
Thu Jul 14 18:58:39 2005 UTC (14 years, 6 months ago) by overbeek
CVS Tags: caBIG-dataload-0
add get_ev_codes
Tue Jul 12 00:34:32 2005 UTC (14 years, 6 months ago) by overbeek
updates to build protein families
