[Bio] / FigKernelScripts / build_prok_nonff_fasta.pl Repository:
Log of /FigKernelScripts/build_prok_nonff_fasta.pl
Thu Nov 11 17:45:25 2010 UTC (9 years ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
FigFam 6 digit problem
Mon Sep 20 20:24:42 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.2: +27 -9 lines
don't include hypotheticals
Thu Apr 1 19:28:40 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.1: +7 -1 lines
figfam build updates
Thu Jan 14 16:41:44 2010 UTC (9 years, 10 months ago) by overbeek
CVS Tags: rast_rel_2010_0118
get non FF prok seqs
