[Bio] / FigKernelScripts / build_nr_sources.pl Repository:
Log of /FigKernelScripts/build_nr_sources.pl
Fri May 11 20:18:06 2007 UTC (12 years, 10 months ago) by olson
Rollup of various rast-related changes.
Fri Mar 23 19:15:39 2007 UTC (13 years ago) by olson
Changes since 1.12: +10 -1 lines
compute_pchs_from_sims.pl
Mon Jan 15 21:46:04 2007 UTC (13 years, 2 months ago) by olson
Changes since 1.11: +47 -2 lines
support getting genome sources from 48hr server
Wed Nov 22 21:00:40 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.10: +18 -0 lines
allow files in ext-dir to supplement files in the FIG/Data/NR dir, not only replace.
Mon Sep 4 20:14:04 2006 UTC (13 years, 7 months ago) by redwards
Changes since 1.9: +2 -1 lines
using is_environmental
Fri May 19 13:44:05 2006 UTC (13 years, 10 months ago) by olson
Changes since 1.8: +43 -4 lines
Some changes to add_genome logic.
(Only log after genome add completes; turn some formerly fatal errors into nonfatal
with warnings so that we don't end up with a partially-added genome).
Thu May 4 18:00:05 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.7: +1 -0 lines
Fri Mar 11 16:08:13 2005 UTC (15 years, 1 month ago) by overbeek
Modified to exclude environmental samples. -- /gdp
Sun Oct 24 17:36:02 2004 UTC (15 years, 5 months ago) by overbeek
Changes since 1.4: +13 -18 lines
Allow Data directory as input to build_nr_sources
Tue Jun 29 19:35:52 2004 UTC (15 years, 9 months ago) by olson
fix dumb typos
Tue Jun 29 19:31:24 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.2: +26 -2 lines
Read FIG files from orgs dir instead of db.
Mon Dec 8 02:45:13 2003 UTC (16 years, 4 months ago) by overbeek
minor fix
Mon Dec 8 02:43:31 2003 UTC (16 years, 4 months ago) by overbeek
add build_nr_sources
