[Bio] / FigKernelScripts / build_initial_objects_for_start_predictions.pl Repository:
Log of /FigKernelScripts/build_initial_objects_for_start_predictions.pl
Links to merge-trunktag-bobdev_news-2: (view) (download) (as text) (annotate)
Thu May 12 20:38:37 2005 UTC (14 years, 7 months ago) by overbeek
add tool to generate gene blocks for variation analysis
Thu Apr 28 19:07:16 2005 UTC (14 years, 7 months ago) by overbeek
minor fix to prediction of starts
Mon Jan 17 01:27:44 2005 UTC (14 years, 10 months ago) by overbeek
add start prediction code
