[Bio] / FigKernelScripts / build_initial_objects_for_start_predictions.pl Repository:
Log of /FigKernelScripts/build_initial_objects_for_start_predictions.pl
Sun Jan 20 21:44:52 2008 UTC (12 years ago) by gdpusch
Changes since 1.11: +29 -23 lines
Diff to previous 1.11 , to selected 1.2
Modified to also work on new genomes using "FIGV.". -- /gdp
Fri Nov 30 21:53:05 2007 UTC (12 years, 1 month ago) by gdpusch
Changes since 1.10: +20 -15 lines
Diff to previous 1.10 , to selected 1.2
Added FIGV support. -- /gdp
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.9: +17 -0 lines
Tue Nov 22 14:57:50 2005 UTC (14 years, 2 months ago) by overbeek
Changes since 1.8: +8 -4 lines
fixes to characterization of hypos
Sat Nov 5 22:59:44 2005 UTC (14 years, 2 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.7: +236 -1 lines
fixes to extract_genomes
Sat Aug 6 14:58:56 2005 UTC (14 years, 5 months ago) by overbeek
CVS Tags: caBIG-dataload-0
fixes to bugs in calling starts
Fri Aug 5 17:43:53 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.5: +1 -2 lines
fix bad bug in calling starts
Thu Jul 28 17:45:37 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.4: +27 -16 lines
modifications to correcting starts code
Sun Jul 24 15:54:40 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.3: +10 -3 lines
fixes to start predictions
Thu May 12 20:38:37 2005 UTC (14 years, 8 months ago) by overbeek
add tool to generate gene blocks for variation analysis
Thu Apr 28 19:07:16 2005 UTC (14 years, 9 months ago) by overbeek
minor fix to prediction of starts
Mon Jan 17 01:27:44 2005 UTC (15 years ago) by overbeek
Diff to selected 1.2
add start prediction code
