[Bio] / FigKernelScripts / boot_cluster_seed.pl Repository:
Log of /FigKernelScripts/boot_cluster_seed.pl
Tue Jan 10 18:39:34 2006 UTC (14 years, 5 months ago) by olson
Changes since 1.4: +43 -22 lines
more checksum fixes. need to replace the "ls -lR" hack with somethign that traverses the treein perl.
Wed Jul 27 22:13:15 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.2: +92 -24 lines
fixes to clster bootup script
Sun May 29 02:15:02 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.1: +65 -49 lines
Updates.
Thu May 12 15:27:50 2005 UTC (15 years, 1 month ago) by olson
Bootup script for cluster node.
