[Bio] / FigKernelScripts / blastp_pseq.pl Repository:
Log of /FigKernelScripts/blastp_pseq.pl
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Wed Aug 11 12:25:13 2004 UTC (15 years, 7 months ago) by olson
Use the proper BLASTMAT location.
Wed Aug 11 12:15:12 2004 UTC (15 years, 7 months ago) by olson
Force blastall and formatdb to be run using a full path to $FIG_Config::ext_bin.
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
Makefile:
All the rest:
