[Bio] / FigKernelScripts / blastp_pseq.pl Repository:
Log of /FigKernelScripts/blastp_pseq.pl
Links to mgrast_dev_12152011: (view) (download) (as text) (annotate)
Sat Aug 29 22:01:03 2009 UTC (10 years, 9 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
adding a default cutoff
Fri Apr 3 20:02:44 2009 UTC (11 years, 1 month ago) by redwards
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09
Changes since 1.4: +3 -1 lines
providing a default database
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Wed Aug 11 12:25:13 2004 UTC (15 years, 9 months ago) by olson
Use the proper BLASTMAT location.
Wed Aug 11 12:15:12 2004 UTC (15 years, 9 months ago) by olson
Force blastall and formatdb to be run using a full path to $FIG_Config::ext_bin.
Mon Dec 1 20:46:40 2003 UTC (16 years, 6 months ago) by efrank
Makefile:
All the rest:
