[Bio] / FigKernelScripts / bielefeld_tarfile_to_seed.pl Repository:
Log of /FigKernelScripts/bielefeld_tarfile_to_seed.pl
Links to caBIG-05Apr06-00: (view) (download) (as text) (annotate)
Tue Nov 22 14:57:50 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.2: +22 -5 lines
fixes to characterization of hypos
Tue Oct 25 11:38:23 2005 UTC (14 years, 7 months ago) by overbeek
CVS Tags: caBIG-00-00-00
Changes since 1.1: +36 -4 lines
Improved handling and testing of file arguments. -- /gdp
Wed Sep 28 21:45:36 2005 UTC (14 years, 8 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Processes a Bielefeld gene-call tarfile to produce a SEED skeleton directory. -- /gdp
