[Bio] / FigKernelScripts / assign_using_ff_parallel.pl Repository:
View of /FigKernelScripts/assign_using_ff_parallel.pl
Revision 1.2 - (download) (as text) (annotate)
Wed Mar 4 15:55:48 2009 UTC (10 years, 11 months ago) by arodri7
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, myrast_rel40, mgrast_dev_05262011, mgrast_dev_04082011, rast_rel_2010_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, rast_rel_2009_07_09, rast_rel_2010_0827, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, mgrast_dev_02222011, rast_rel_2009_03_26, mgrast_dev_10262011, HEAD
Changes since 1.1: +49 -12 lines
made updates to functions used for updating FIGfams
#use strict;
use FIG;
my $fig = new FIG;
my $usage = "usage: assign_using_ff_parallel [-d] [-l] [-f] [-n] [-p] Dir nodes [outputF]";
my ($dir,$procs,$outD);
my $debug;
my $loose = 0;
my $full = 0;
my ($print_sims, $nuc);
while ( $ARGV[0] =~ /^-/ )
    $_ = shift @ARGV;
    if       ($_ =~ s/^-l//)   { $loose         = 1 }
    elsif    ($_ =~ s/^-f//)   { $full          = 1 }
    elsif    ($_ =~ s/^-b//)   { $bulk           = 1 }
    elsif    ($_ =~ s/^-d//)   { $debug         = 1 }
    elsif    ($_ =~ s/^-n//)   { $nuc           = 1 }
    elsif    ($_ =~ s/^-p//)   { $print_sims    = 1 }
    else                       { print STDERR  "Bad flag: '$_'\n$usage"; exit 1 }
($dir = shift @ARGV)
    || die $usage;
($procs = shift @ARGV)
    || ($procs = 8);
($outF = shift @ARGV);
use FF;
use FFs;
my $figfams = new FFs($dir);
my @args;
push (@args, "-l") if $loose;
push (@args, "-d") if $debug;
push (@args, "-n") if $nuc;
push (@args, "-p") if $print_sims;
push (@args, "-f") if $full;
push (@args, "-b") if $bulk;
my $seen = {};
if ($outF){
    my @outfiles = glob ("$outF*");
    $\="\t//\n";
    foreach my $file (@outfiles){
	open (FH, "<$file");
	while (my $result = <FH>){
	    my ($id) = $result =~ /^(.*?)\s/;
	    $seen->{$id} =1;
	close FH;
    $\="\n";
print STDERR "Complete: " . scalar( keys %$seen) . "\n";
my $arg = join " ", @args;
my @procs = &start_procs("assign_using_ff $arg $dir", $outF, $procs);
my $nextP = 0;
my $line = <STDIN>;
while ($line && ($line =~ /^>(\S+)/))
    my $id = $1;
    my @seq = ();
    while (defined($line = <STDIN>) && ($line !~ /^>/))
	$line =~ s/\s//g;
	push(@seq,$line);
    my $seq = join("",@seq);
    $total++;
    if ($seen->{$id}){
	delete $seen->{$id};
	next;
    $total_submit++;
    # get filehandle
    my $fh = $procs[$nextP];
    #print STDERR *$fh . "\n";
    #print STDERR "$fh $id\n";
    print $fh ">$id\n$seq\n";
    $nextP = ($nextP == $#procs) ? 0 : $nextP+1;
print STDERR "Total seqs: $total\n";
print STDERR "Submitted seqs: $total_submit\n";
&close_procs(\@procs);
my @outs = glob ("out_*");
foreach my $file (@outs){
    `cat $file`;
    #unlink $file;
sub start_procs {
    my($cmd, $outF, $procsN) = @_;
    my @procs = ();
    for (my $i=1;$i<=$procsN;$i++){
	my $fh = "F".$i;
	open($fh,"| $cmd $outF") || die $i;
#	open(F1,"| $cmd") || die $i;
	my $ofh = select $fh; $| = 1; select $ofh;
	push(@procs,\*$fh);
	print STDERR "starting process $i\n";
    return @procs;
sub close_procs {
    my($procs) = @_;
    my $proc;
    for (my $i=0; ($i < @$procs); $i++)
	print STDERR "CLOSING ",$i+1,"\n";
	my $fh = $procs->[$i];
	print $fh "x\n";
	close($fh);
	print STDERR "CLOSED ",$i+1,"\n";
