[Bio] / FigKernelScripts / assign_towards_subsystems.pl Repository:
Log of /FigKernelScripts/assign_towards_subsystems.pl
Wed Aug 17 15:41:21 2005 UTC (14 years, 7 months ago) by redwards
Initial release of a more relaxed assignment script. Prefers (with limits) to put things in SS
