[Bio] / FigKernelScripts / assign_to_close_strains.pl Repository:
Log of /FigKernelScripts/assign_to_close_strains.pl
Links to rast_rel_2011_0928: (view) (download) (as text) (annotate)
Wed May 3 15:55:21 2006 UTC (13 years, 11 months ago) by overbeek
fixes to Assignments.pm
Sun Feb 19 20:03:54 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.8: +49 -5 lines
add tools for building FIG protein families
Wed Feb 15 22:12:26 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.7: +29 -11 lines
minor fixes to assignment for close strains
Fri Jun 3 14:32:27 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.5: +5 -434 lines
clean up of auto assignments routines
Fri Jun 3 13:26:36 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.4: +23 -2 lines
fixes to processing cluster spreadsheets
Fri May 27 14:42:19 2005 UTC (14 years, 10 months ago) by overbeek
cleaned up auto_assign
Fri May 27 14:03:06 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.2: +219 -17 lines
upgrade assign_to_close_strains
Tue May 3 00:09:39 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.1: +15 -4 lines
add make_PHOBs_for subsystems
Fri Apr 29 16:43:29 2005 UTC (14 years, 11 months ago) by overbeek
add assign_to_close_strains
