[Bio] / FigKernelScripts / assign_to_close_strains.pl Repository:
Log of /FigKernelScripts/assign_to_close_strains.pl
Links to caBIG-00-00-00: (view) (download) (as text) (annotate)
Fri Jun 3 14:32:27 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.5: +5 -434 lines
clean up of auto assignments routines
Fri Jun 3 13:26:36 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.4: +23 -2 lines
fixes to processing cluster spreadsheets
Fri May 27 14:42:19 2005 UTC (14 years, 10 months ago) by overbeek
cleaned up auto_assign
Fri May 27 14:03:06 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.2: +219 -17 lines
upgrade assign_to_close_strains
Tue May 3 00:09:39 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.1: +15 -4 lines
add make_PHOBs_for subsystems
Fri Apr 29 16:43:29 2005 UTC (14 years, 11 months ago) by overbeek
add assign_to_close_strains
