[Bio] / FigKernelScripts / assign_synonym_ids_to_nr.pl Repository:
Log of /FigKernelScripts/assign_synonym_ids_to_nr.pl
Tue Sep 27 16:02:54 2005 UTC (14 years, 4 months ago) by olson
Scripts for assigning xxx numbers to peg.syn and friends.
