[Bio] / FigKernelScripts / assign_synonym_ids_to_nr.pl Repository:
Log of /FigKernelScripts/assign_synonym_ids_to_nr.pl
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Tue Sep 27 16:02:54 2005 UTC (14 years, 2 months ago) by olson
Scripts for assigning xxx numbers to peg.syn and friends.
