[Bio] / FigKernelScripts / assign_synonym_ids.pl Repository:
Log of /FigKernelScripts/assign_synonym_ids.pl
Mon Dec 5 18:56:37 2005 UTC (14 years, 6 months ago) by olson
Tue Sep 27 16:02:54 2005 UTC (14 years, 8 months ago) by olson
Scripts for assigning xxx numbers to peg.syn and friends.
