[Bio] / FigKernelScripts / apply_peg_changes_to_subsystem.pl Repository:
View of /FigKernelScripts/apply_peg_changes_to_subsystem.pl
Revision 1.3 - (download) (as text) (annotate)
Mon Dec 5 18:56:37 2005 UTC (14 years, 6 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
# Public License.
# Given a set of peg-update transaction log files of the form:
# change old-id new-id contig protein-seq
# del id
# add id contig protein-seq
# And a list of subsystems, modify the subsystems in place (writing backups
# as usual) to remove the deleted ids and change any occurrences of the old ids to
# the corresponding new id.
use strict;
use Data::Dumper;
use FIG;
my $fig = new FIG;
my $usage = "apply_peg_changes_to_subsystem transaction-log-files... [-subsystems subsystem names]";
my(@trans_files, @subs);
my $mode = 'trans';
while (@ARGV)
    $_ = shift;
    if (/^-(.*)/)
	if ($1 eq "subsystems")
	    $mode = 'subsystems';
	else
	    die $usage;
    elsif ($mode eq 'trans')
	push(@trans_files, $_);
    elsif ($mode eq 'subsystems')
	push(@subs, $_);
my($trans_table, $genomes_seen) = read_trans_files(\@trans_files);
if (@subs == 0)
    @subs = sort $fig->all_subsystems();
for my $sub (@subs)
    fix_subsystem($sub, $trans_table, $genomes_seen);
sub fix_subsystem
    my($sname, $actions, $genomes_seen) = @_;
    my $sub = $fig->get_subsystem($sname);
    $sub or die "Cannot find subsystem $sname\n";
    my $modified;
    for my $genome (@$genomes_seen)
	my $row_idx = $sub->get_genome_index($genome);
	next unless $row_idx;
	my $row = $sub->get_row($row_idx);
	my $tchange = 0;
	my $tdel = 0;
	for my $cell (@$row)
	    my @ncell = ();
	    my $change = 0;
	    my $del = 0;
	    for my $peg (@$cell)
		my $action = $actions->{$peg};
		if ($action eq 'del')
		    $del++;
		elsif ($action =~ /^fig\|(\d+\.\d+)/)
		    if ($1 ne $genome)
			die "Invalid replacement $peg -> $action in $sname";
		    push(@ncell, $action);
		    $change++;
		else
		    push(@ncell, $peg);
	    if ($change or $del)
		@$cell = @ncell;
		$tdel += $del;
		$tchange += $change;
	if ($tdel or $tchange)
	    if (not $modified)
		my $cur = $sub->get_curator;
		print "$sname\t$cur\n";
	    print "  $genome\t$tdel deletes\t$tchange changes\n";
	    $modified++;
    if ($modified)
	$sub->write_subsystem(1);
sub read_trans_files
    my($files) = @_;
    my $actions = {};
    my %genomes_seen;
    for my $file (@$files)
	open(F, "<$file") or die "Cannot open transaction file $file: $!";
	while (<F>)
	    chomp;
	    my($type, @args) = split(/\t/);
	    if ($type eq 'del')
		$actions->{$args[0]} = 'del';
		$genomes_seen{$fig->genome_of($args[0])}++;
	    elsif ($type eq 'change')
		$actions->{$args[0]} = $args[1];
	    elsif ($type eq 'add')
	    else
		die "Invalid action at $file line $.";
    return $actions, [sort keys %genomes_seen];
