[Bio] / FigKernelScripts / apply_automatic_subsystem_updates.pl Repository:
Log of /FigKernelScripts/apply_automatic_subsystem_updates.pl
Tue Jun 21 21:37:44 2011 UTC (8 years, 4 months ago) by olson
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Scripts to run rapid_subsystem_inference_batch across all genomes, and to apply
the missing-in-subsystems output of that script to update subsystems.
