[Bio] / FigKernelScripts / analyze_loose_sets.pl Repository:
Log of /FigKernelScripts/analyze_loose_sets.pl
Thu Apr 21 21:04:15 2011 UTC (8 years, 11 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +15 -3 lines
Added CSV output that can be used to generate a spreadsheet of recommended functional assignments.
Mon Apr 18 16:28:59 2011 UTC (8 years, 11 months ago) by parrello
Changes since 1.1: +56 -16 lines
Added a new rule relating to hypothetical proteins.
Thu Apr 14 21:12:35 2011 UTC (8 years, 11 months ago) by parrello
Added support for analyzing functions to look for fix recommendations.
