[Bio] / FigKernelScripts / align_with_clustal_2.pl Repository:
Log of /FigKernelScripts/align_with_clustal_2.pl
Mon Apr 9 21:01:27 2007 UTC (12 years, 7 months ago) by golsen
Trivial format change.
Mon Dec 5 18:56:37 2005 UTC (13 years, 11 months ago) by olson
Wed Nov 30 09:18:08 2005 UTC (13 years, 11 months ago) by golsen
Changes since 1.1: +4 -5 lines
Fix the clustalw command so that it really uses the final alignment
for the tree (it seems that it is not possible to combine the -align
and -tree command flags in a single command, so it is now run as two
commands).
Wed Nov 30 08:44:26 2005 UTC (13 years, 11 months ago) by golsen
Introduce a different tree printing routine to fid_checked.  This required
a new version of align_with_clustal.pl (= align_with_clustal_2.pl) and a
new tree utilities library (gjonewicklib.pm).
The new tree printer does not require deleting the extra lines (they are
not included in the first place).  This would probably allow some other
restructuring of the code in fid_checked, but I did the minimum.
The other reason for the changes (actually the real reason) is that it is
now possible to introduce midpoint rooting to the tree, and to reorder
the taxa so that the tree is MUCH easier to read (aesthetic tree order).
Also I'm changing it to use a second-generation tree from the alignment,
not just show the guide tree.
