[Bio] / FigKernelScripts / align_with_clustal.pl Repository:
Log of /FigKernelScripts/align_with_clustal.pl
Mon Dec 5 18:56:37 2005 UTC (14 years, 1 month ago) by olson
Changes since 1.7: +17 -0 lines
Mon Feb 14 00:57:27 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.6: +0 -1 lines
minor fixes to alignments
Wed Feb 9 20:15:42 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.5: +9 -1 lines
put UniProt ids in trees of columns
Fri Nov 12 03:48:02 2004 UTC (15 years, 2 months ago) by overbeek
fix bug in -save parm for align_with_clustal
Fri Nov 12 03:15:25 2004 UTC (15 years, 2 months ago) by overbeek
Changes since 1.3: +12 -2 lines
make it possible to save alignments
Wed Aug 4 22:58:40 2004 UTC (15 years, 5 months ago) by gdpusch
Changes since 1.2: +34 -8 lines
Added flags to control whether the genome and function are appended to the IDs.
Wed May 19 21:34:22 2004 UTC (15 years, 8 months ago) by overbeek
fixed multiple identical rows in ssa due to import
Mon Dec 1 20:46:40 2003 UTC (16 years, 1 month ago) by efrank
Makefile:
All the rest:
