[Bio] / FigKernelScripts / align_fasta.pl Repository:
Log of /FigKernelScripts/align_fasta.pl
Tue Jan 19 01:57:39 2010 UTC (10 years, 1 month ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +26 -108 lines
Add support for alignment with muscle.
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Tue Jun 7 02:25:13 2005 UTC (14 years, 8 months ago) by golsen
add_to_alignment FastaAlignment FastaSeqs > NewFastaAlignment
   - Add new sequences to an alignment without altering the relative
     alignments of the previous sequences.  New sequences are added
     one at a time, so their relative alignment (if any) is lost.
     The full sequence ids and descriptions are saved.
align_fasta  < FastaSeqs > FastaAlignment
   - Uses clustalw to produce an alignment from unaligned sequences.
     Deals with issues of clustal corrupting names.
clustal2fasta < Clustal.aln > FastaAlignment
   - Just a fairly clean clustal alignment reformatter.
