[Bio] / FigKernelScripts / ali_to_seq.pl Repository:
View of /FigKernelScripts/ali_to_seq.pl
Revision 1.2 - (download) (as text) (annotate)
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
# Public License.
# usage: ali_to_seq < ali > seqs
$/ = "\n>";
while (defined($_ = <STDIN>))
    chomp;
    if ($_ =~ /^>?(\S+)[^\n]*\n(.*)/s)
	$id  =  $1;
	$seq =  $2;
	$seq =~ s/\n//gs;
	$seq =~ s/ //gs;
	$seq =~ s/[\-\.\~]//gs;
	$seq = lc $seq;
	$seq =~ s/u/t/g;
	&display_id_and_seq($id,\$seq);
sub display_id_and_seq {
    my( $id, $seq, $fh ) = @_;
    if (! defined($fh) )  { $fh = \*STDOUT; }
    print $fh ">$id\n";
    &display_seq($seq, $fh);
sub display_seq {
    my ( $seq, $fh ) = @_;
    my ( $i, $n, $ln );
    $n = length($$seq);
#   confess "zero-length sequence ???" if ( (! defined($n)) || ($n == 0) );
    for ($i=0; ($i < $n); $i += 60)
	if (($i + 60) <= $n)
	    $ln = substr($$seq,$i,60);
	else
	    $ln = substr($$seq,$i,($n-$i));
	print $fh "$ln\n";
