[Bio] / FigKernelScripts / add_structured_english.pl Repository:
Log of /FigKernelScripts/add_structured_english.pl
Links to rast_rel_2008_10_09: (view) (download) (as text) (annotate)
Tue Jun 24 15:15:48 2008 UTC (11 years, 7 months ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Added escape arg to structured engkish
Mon Jun 23 20:20:09 2008 UTC (11 years, 8 months ago) by disz
Changes since 1.2: +13 -145 lines
Moved english part to FIG.pm
Fri May 23 20:53:03 2008 UTC (11 years, 9 months ago) by olson
Changes since 1.1: +31 -6 lines
Fixes for NCBI upload.
Mon May 19 18:02:28 2008 UTC (11 years, 9 months ago) by disz
Ross's code to generate annotations for NCBI
