[Bio] / FigKernelScripts / aclh.pl Repository:
Log of /FigKernelScripts/aclh.pl
Mon Feb 4 20:20:19 2008 UTC (12 years, 1 month ago) by paarmann
added new parameter to dump contribs
Thu Dec 13 20:00:54 2007 UTC (12 years, 3 months ago) by paarmann
Changes since 1.9: +29 -1 lines
count and export options
Wed Nov 7 16:31:29 2007 UTC (12 years, 4 months ago) by olson
ambiguous mapping check on import; fix import bug.
Wed Nov 7 15:40:38 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.7: +12 -0 lines
multiple id support, build fixes
Tue Nov 6 21:44:31 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.6: +21 -0 lines
import_user_annotations now returns in the \@badlist argument a list of the annotations that do not map.
Add aclh command "import" to invoke the import_user_annotations method.
Tue Nov 6 18:48:24 2007 UTC (12 years, 4 months ago) by olson
Changes since 1.5: +21 -0 lines
add check_file method
Fri Sep 14 20:14:57 2007 UTC (12 years, 6 months ago) by olson
doh. fix the method name.
Fri Sep 14 20:03:38 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.3: +2 -1 lines
add help msg
Fri Sep 14 20:01:47 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.2: +6 -0 lines
Add get_user suppor to aclh
Fri Sep 14 15:57:43 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.1: +15 -11 lines
Add purge-user-annotations support.
Wed Aug 15 18:26:27 2007 UTC (12 years, 7 months ago) by olson
New clearinghouse stuff.
