[Bio] / FigKernelScripts / TransactFeatures.pl Repository:
Log of /FigKernelScripts/TransactFeatures.pl
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Tue Feb 5 03:54:42 2008 UTC (12 years, 2 months ago) by parrello
Changes since 1.19: +1 -2 lines
Diff to previous 1.19 , to selected 1.16
Removed obsolete use clause.
Tue Oct 3 02:49:24 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.18: +1 -0 lines
Diff to previous 1.18 , to selected 1.16
Fixed default trace level.
Sun Jan 15 21:29:41 2006 UTC (14 years, 2 months ago) by parrello
Changes since 1.17: +7 -10 lines
Diff to previous 1.17 , to selected 1.16
Converted to use "StandardSetup".
Wed Dec 7 19:38:22 2005 UTC (14 years, 4 months ago) by golsen
Diff to previous 1.16
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Revision 1.16 - (view) (download) (as text) (annotate) - [selected]
Changes since 1.15: +17 -0 lines
Mon Sep 12 00:24:37 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.14: +6 -3 lines
Diff to previous 1.14 , to selected 1.16
Fixed documentation.
Added back the ability to generate TBL output files.
Thu Sep 1 09:39:31 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.13: +12 -45 lines
Diff to previous 1.13 , to selected 1.16
Cleaned up transaction processing.
Mon Aug 15 21:36:28 2005 UTC (14 years, 7 months ago) by parrello
Diff to previous 1.12 , to selected 1.16
Fixed an error in the "start=" parameter.
Mon Aug 15 21:08:56 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.11: +19 -3 lines
Diff to previous 1.11 , to selected 1.16
Added the ability to start in the middle of a transaction run.
Mon Aug 15 20:42:31 2005 UTC (14 years, 7 months ago) by parrello
Diff to previous 1.10 , to selected 1.16
Mon Aug 15 20:40:22 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.9: +6 -0 lines
Diff to previous 1.9 , to selected 1.16
Added a check-only version of the attribute command.
Mon Aug 15 20:29:10 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.8: +7 -0 lines
Diff to previous 1.8 , to selected 1.16
Added a command fort copying attributes from old features to their replacements.
Fri Aug 12 09:33:50 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.7: +22 -4 lines
Diff to previous 1.7 , to selected 1.16
Added a new command to extract the old alias values for the changed features and move them to the new features.
Thu Aug 11 16:36:01 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.6: +7 -3 lines
Diff to previous 1.6 , to selected 1.16
Changed the "fix" command to fix incorrect locations and translations. Added "check" command that looks for errors but does not fix them.
Thu Aug 11 05:16:46 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.5: +4 -2 lines
Diff to previous 1.5 , to selected 1.16
Fixed a bug in the handling of the "annotate" command.
Thu Aug 11 04:14:45 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.4: +11 -1 lines
Diff to previous 1.4 , to selected 1.16
Added a "noAlias" option to handle the lack of an alias field in the input files.
Thu Aug 11 03:19:31 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.3: +10 -0 lines
Diff to previous 1.3 , to selected 1.16
Updated documentation.
Thu Aug 11 03:10:35 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.2: +31 -478 lines
Diff to previous 1.2 , to selected 1.16
Converted the transaction processor to an object-oriented module in order to simplify the task of programming the ever-growing number of scripts that use them.
Tue Aug 9 00:57:48 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.1: +21 -6 lines
Diff to previous 1.1 , to selected 1.16
Added an option to allow wrapping each genome's transactions in a database transaction.
Mon Aug 8 20:13:08 2005 UTC (14 years, 8 months ago) by parrello
Diff to selected 1.16
New script to process transaction files containing commands to add, delete, and replace features.
