[Bio] / FigKernelScripts / Packager.pl Repository:
Log of /FigKernelScripts/Packager.pl
Thu Dec 6 14:00:37 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.6: +26 -26 lines
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Wed Oct 12 02:52:46 2005 UTC (14 years, 4 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.3: +4 -2 lines
Moved from the WinBuild directory.
Mon Sep 12 00:25:22 2005 UTC (14 years, 5 months ago) by parrello
CVS Tags: caBIG-dataload-0
Changes since 1.2: +23 -8 lines
Fixed documentation.
Wed Aug 17 02:37:07 2005 UTC (14 years, 6 months ago) by parrello
Changes since 1.1: +9 -3 lines
Fixed to skip ".old" directories.
Tue Aug 16 22:38:36 2005 UTC (14 years, 6 months ago) by parrello
Fixed to add checksums to the package file and moved into the main script directory.
