[Bio] / FigKernelScripts / NMPDRAnalysis.pl Repository:
Log of /FigKernelScripts/NMPDRAnalysis.pl
Tue Feb 5 02:54:29 2008 UTC (12 years ago) by parrello
Changes since 1.4: +0 -2 lines
Removed obsolete use clauses.
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Mon Sep 12 00:22:08 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.1: +15 -2 lines
Fixed the documentation.
Tue Aug 16 00:05:59 2005 UTC (14 years, 6 months ago) by parrello
Added to permit creating lists of NMPDR core and supporting genomes.
