[Bio] / FigKernelScripts / Makefile Repository:
Log of /FigKernelScripts/Makefile
Links to mgrast_dev_10262011: (view) (download) (annotate)
Revision 1.27 - (view) (download) (annotate) - [select for diffs]
Wed Aug 3 18:52:11 2011 UTC (8 years, 6 months ago) by disz
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Changes since 1.26: +1 -0 lines
Diff to previous 1.26
Added to_run_new_genomes
Tue Jun 14 18:18:17 2011 UTC (8 years, 8 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_1, myrast_rel40
Changes since 1.25: +3 -1 lines
Diff to previous 1.25
Add annotation push script
Mon Jun 13 20:27:46 2011 UTC (8 years, 8 months ago) by disz
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
Added to_run_daily.sh
Tue Apr 5 16:06:18 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0
Diff to previous 1.23
fix R build target. why it works for me and not elsewhere I don't know
Thu Jan 6 22:57:05 2011 UTC (9 years, 1 month ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, myrast_33, rast_rel_2011_0119
Changes since 1.22: +4 -1 lines
Diff to previous 1.22
more expression hacking fixes
Mon Apr 19 20:27:00 2010 UTC (9 years, 10 months ago) by overbeek
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.21: +6 -0 lines
Diff to previous 1.21
copy R scripts too
Mon Jun 23 16:39:36 2008 UTC (11 years, 8 months ago) by olson
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Diff to previous 1.20
add md5 modl
Tue Dec 4 20:09:03 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.19: +3 -1 lines
Diff to previous 1.19
Rollup of release engineering changes that shoudl  make multi-architecture
installs happier.
Wed Apr 11 17:47:15 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.18: +2 -0 lines
Diff to previous 1.18
rollup of metagenome server changes
Changes since 1.17: +17 -0 lines
Diff to previous 1.17
Wed Aug 31 21:14:32 2005 UTC (14 years, 5 months ago) by overbeek
Diff to previous 1.16
Added rule for "fastasize.c"
Wed Apr 13 02:26:57 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.15: +15 -49 lines
this, combined with head for ReleaseTools should do reasonable thing
for .c code
Tue Apr 12 21:19:57 2005 UTC (14 years, 10 months ago) by efrank
Changes since 1.14: +48 -13 lines
revert to efrank-preMakefileToStandardMk to set head of cvs state
until i return
Tue Apr 12 20:43:43 2005 UTC (14 years, 10 months ago) by efrank
CVS Tags: partialStandardMkMigration
Changes since 1.13: +13 -48 lines
This largely migrates the makefile to use standard.mk.  In particular,
it moves the .c compilation residue out to $(workdir) so that the
source dir stays clean.
this builds but does not link.  i think there's an md5 dependency that
my local env can't meet?
if this is a disaster, there's a tag efrank-preMakefileToStandardMk on
this package before my work that can be revived.
Wed Mar 30 00:09:40 2005 UTC (14 years, 10 months ago) by golsen
Added fastasize to list of C programs.
Wed Mar 9 01:48:24 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.11: +4 -2 lines
Fix C compile to find perl includes in the current environment.
Tue Mar 8 21:06:04 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.10: +6 -1 lines
Add support for computing MD5 checksums for contigs and genomes.
The checksum of a genome is defined as the checksum of its signature file. The signature
file consists of tab-separated lines, one for each contig, ordered by the contig id.
Each line contains the contig ID, the length of the contig in nucleotides, and the
MD5 checksum of the nucleotide data, with uppercase letters forced to lower case.
The signature file is written by index_contigs to
The genome's md5 checksum is written by index_contigs to <genomedir>/MD5SUM.
The md5.c code here is extracted from the Perl Digest::MD5 module. We use the perl
configuration to build it so that it will work correctly on 64-bit architectures.
Fri Nov 19 22:02:55 2004 UTC (15 years, 3 months ago) by olson
Changes since 1.9: +3 -0 lines
Fix makefiles for change in releasetools.
Wed Sep 29 18:22:53 2004 UTC (15 years, 4 months ago) by olson
Changes since 1.8: +2 -0 lines
Changes for new toplevel makefile structure.
Tue Aug 24 22:11:50 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.7: +19 -1 lines
Gary Olsen's optimized database loading code.
This probably needs to be tweaked to use the full path (FIG_Config::bin/<app>), but I
want to get this committed today.
Wed Jun 16 16:08:20 2004 UTC (15 years, 8 months ago) by olson
Changes since 1.6: +7 -1 lines
Clean up map support.
Tue Dec 23 19:20:44 2003 UTC (16 years, 2 months ago) by olson
Changes since 1.5: +2 -4 lines
new build structure.
Wed Dec 3 02:31:02 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-01, delong-01, delong-02
Changes since 1.4: +17 -3 lines
   o removed the files that are generated by configure-env
   o removed FIG_Config.pm from every package where it existed:
     we generate it now.
   o Modified makefiles to all have lib bin clean and test targets
     although some don't do anything
   o Modified makefiles to call configure-env to generate files needed.
     This needs to be improved in the future.
Tue Dec 2 23:46:04 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.3: +0 -2 lines
removef all: target.
Mon Dec 1 20:58:35 2003 UTC (16 years, 2 months ago) by efrank
CVS Tags: V00-00-00
Use PKGNAME macro from the top makefile
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Changes since 1.1: +12 -17 lines
Makefile:
All the rest:
Mon Dec 1 16:55:42 2003 UTC (16 years, 2 months ago) by efrank
Branch point for: initial
