[Bio] / FigKernelScripts / Makefile.cprogs Repository:
Log of /FigKernelScripts/Makefile.cprogs
Mon Dec 3 16:56:03 2007 UTC (11 years, 11 months ago) by olson
Changes since 1.1: +7 -1 lines
Support compilation of nap.c
Tue Nov 20 22:56:07 2007 UTC (12 years ago) by olson
Standalone makefile for the C programs (used in building CEE)
