[Bio] / FigKernelScripts / FFB3_assemble_translations.pl Repository:
Log of /FigKernelScripts/FFB3_assemble_translations.pl
Tue Jul 9 16:49:46 2013 UTC (6 years, 4 months ago) by olson
FFB3_build_updated_FF: Add --temp to force use of given temp directory
Change hardcoded database host to seed-db-read for the annotator seed.
Tue Jan 10 13:18:14 2012 UTC (7 years, 10 months ago) by olson
CVS Tags: mgrast_version_3_2
New figfam building code.
