[Bio] / FigKernelScripts / FFB2_usable_motifs.pl Repository:
Log of /FigKernelScripts/FFB2_usable_motifs.pl
Fri Oct 29 17:10:34 2010 UTC (9 years ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +5 -0 lines
Update to FF processing
Tue Jul 13 12:06:06 2010 UTC (9 years, 4 months ago) by olson
Changes since 1.2: +26 -4 lines
More fixes; only generate 8mers for OTUs; add skipotu option.
Mon Jul 12 19:30:27 2010 UTC (9 years, 4 months ago) by olson
Changes since 1.1: +55 -19 lines
Bunch of figfam generation optimizations.
Mon Nov 16 21:52:22 2009 UTC (9 years, 11 months ago) by overbeek
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
new scripts for updating FIGfams and Kmer tables
