[Bio] / FigKernelScripts / FFB2_update_FIGfams.pl Repository:
Log of /FigKernelScripts/FFB2_update_FIGfams.pl
Tue Nov 30 00:16:46 2010 UTC (9 years, 2 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
fix memcache stuff
Mon Nov 29 22:25:34 2010 UTC (9 years, 2 months ago) by olson
Changes since 1.14: +129 -15 lines
updates
Mon Nov 22 20:06:09 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.13: +68 -17 lines
More memcache fixes.
Mon Nov 22 18:07:47 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.12: +4 -2 lines
clean up functions coming from override file
Mon Nov 22 17:41:30 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.11: +27 -14 lines
Big round of figfam update changes
Thu Nov 11 17:47:43 2010 UTC (9 years, 3 months ago) by disz
Changes since 1.10: +11 -11 lines
FigFam 6 digit problem
Wed Nov 10 15:38:01 2010 UTC (9 years, 3 months ago) by overbeek
Changes since 1.9: +8 -3 lines
add FIGfam ID to hypothetical proteins
Tue Nov 9 22:14:29 2010 UTC (9 years, 3 months ago) by olson
Changes since 1.8: +1 -0 lines
New FIGfam merge code.
Sat Aug 14 04:05:06 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.7: +17 -4 lines
bugfixes
Thu Aug 12 19:17:41 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.6: +23 -0 lines
fix nasty little bug
Mon Jul 12 19:30:27 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.5: +43 -13 lines
Bunch of figfam generation optimizations.
Wed Jun 23 21:16:51 2010 UTC (9 years, 8 months ago) by olson
Rollup of figfam update fixes
Tue Jun 8 18:25:09 2010 UTC (9 years, 8 months ago) by olson
Changes since 1.3: +24 -16 lines
Do not prepend FIGXXXX to family functions.
Wed Apr 7 16:54:39 2010 UTC (9 years, 10 months ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.2: +4 -2 lines
add missing use
Mon Apr 5 20:05:03 2010 UTC (9 years, 10 months ago) by overbeek
Changes since 1.1: +10 -22 lines
fixes to resetting functions
Mon Nov 16 21:52:22 2009 UTC (10 years, 3 months ago) by overbeek
CVS Tags: rast_rel_2010_0118
new scripts for updating FIGfams and Kmer tables
