[Bio] / FigKernelScripts / FFB2_run_tests.pl Repository:
Log of /FigKernelScripts/FFB2_run_tests.pl
Mon Feb 14 22:44:07 2011 UTC (8 years, 9 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +21 -5 lines
Update to figfam build code
Tue Jun 8 18:26:04 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.1: +11 -0 lines
Add Kmer installer script.
Add metabolic reconstruction computation to the test runs.
Thu Apr 1 19:28:40 2010 UTC (9 years, 8 months ago) by olson
CVS Tags: rast_rel_2010_0526
figfam build updates
