[Bio] / FigKernelScripts / FFB2_merge_families_based_on_genus_groups.pl Repository:
Log of /FigKernelScripts/FFB2_merge_families_based_on_genus_groups.pl
Mon Nov 22 17:41:30 2010 UTC (9 years ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +176 -38 lines
Big round of figfam update changes
Thu Nov 11 17:48:43 2010 UTC (9 years ago) by disz
FigFam 6 digit problem
Tue Nov 9 22:14:29 2010 UTC (9 years ago) by olson
New FIGfam merge code.
