[Bio] / FigKernelScripts / FFB2_make_subsys_based_families.pl Repository:
Log of /FigKernelScripts/FFB2_make_subsys_based_families.pl
Mon Jul 12 19:30:27 2010 UTC (9 years, 10 months ago) by olson
Changes since 1.1: +42 -8 lines
Bunch of figfam generation optimizations.
Mon Nov 16 21:52:22 2009 UTC (10 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
new scripts for updating FIGfams and Kmer tables
