Log of /FigKernelScripts/FFB2_build_updated_FF.pl
Parent Directory
Revision
1.23 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Feb 14 22:44:07 2011 UTC (8 years, 10 months ago) by
olson
Branch:
MAIN
CVS Tags:
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
myrast_rel40,
rast_rel_2011_0928
Changes since
1.22: +2 -0 lines
Diff to
previous 1.22
to
selected 1.8
Update to figfam build code
Revision
1.11 -
view)
download)
as text)
annotate)
[select for diffs]
Mon Jul 12 21:06:53 2010 UTC (9 years, 5 months ago) by
olson
Branch:
MAIN
Changes since
1.10: +3 -1 lines
Diff to
previous 1.10
to
selected 1.8
Sort get_oligos output in 10M oligo chunks with an explicit merge when done, so we
can better overlap the actual get_oligos computation with the sorts.
Revision
1.8 -
view)
download)
as text)
annotate)
[selected]
Mon Jul 12 19:30:27 2010 UTC (9 years, 5 months ago) by
olson
Branch:
MAIN
Changes since
1.7: +89 -13 lines
Diff to
previous 1.7
Bunch of figfam generation optimizations.
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
