[Bio] / FigKernelScripts / CS_compute_coupling.pl Repository:
Log of /FigKernelScripts/CS_compute_coupling.pl
Fri May 9 17:16:20 2014 UTC (5 years, 6 months ago) by overbeek
take gids from genome.names
Thu May 8 19:56:10 2014 UTC (5 years, 6 months ago) by overbeek
fix for kbase
Thu May 8 12:55:06 2014 UTC (5 years, 6 months ago) by overbeek
make genome: in new locs optional
Thu May 8 12:43:24 2014 UTC (5 years, 6 months ago) by overbeek
Changes since 1.1: +4 -3 lines
remove dependency on pubSEED
Thu Apr 3 20:24:16 2014 UTC (5 years, 7 months ago) by overbeek
get coupling data for WC
