[Bio] / FigKernelScripts / CSA_make_unique_kmers.pl Repository:
Log of /FigKernelScripts/CSA_make_unique_kmers.pl
Tue Jul 19 20:15:00 2011 UTC (8 years, 8 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
make sorts in local dir, not /tmp
Mon Jun 27 17:13:58 2011 UTC (8 years, 9 months ago) by overbeek
CVS Tags: myrast_rel40
Changes since 1.2: +3 -0 lines
make part of myRAST distribution
Sat Jun 18 21:48:07 2011 UTC (8 years, 9 months ago) by overbeek
minor fixes
Thu Jun 16 14:38:26 2011 UTC (8 years, 9 months ago) by overbeek
close strain update
