[Bio] / FigKernelScripts / CSA_make_contig_index.pl Repository:
Log of /FigKernelScripts/CSA_make_contig_index.pl
Mon Jun 27 17:13:58 2011 UTC (8 years, 7 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +3 -0 lines
make part of myRAST distribution
Thu Jun 16 14:38:26 2011 UTC (8 years, 8 months ago) by overbeek
close strain update
