[Bio] / FigKernelScripts / CSA_get_close_strain_annotations.pl Repository:
Log of /FigKernelScripts/CSA_get_close_strain_annotations.pl
Fri Jul 1 16:57:44 2011 UTC (8 years, 4 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
spelling errors
Thu Jun 30 19:01:20 2011 UTC (8 years, 4 months ago) by overbeek
delete MADE IT message
Mon Jun 27 17:13:58 2011 UTC (8 years, 4 months ago) by overbeek
CVS Tags: myrast_rel40
Changes since 1.2: +3 -0 lines
make part of myRAST distribution
Sun Jun 19 01:42:01 2011 UTC (8 years, 5 months ago) by overbeek
save translations for ref genome
Sun Jun 19 01:33:46 2011 UTC (8 years, 5 months ago) by overbeek
gather mappings into annotations
