[Bio] / FigKernelScripts / CSA_build_alignments.pl Repository:
Log of /FigKernelScripts/CSA_build_alignments.pl
Mon Jul 18 22:58:12 2011 UTC (8 years, 7 months ago) by overbeek
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_1_1, rast_rel_2011_0928
Changes since 1.14: +12 -3 lines
fixes to VCS stuff
Fri Jul 15 12:51:04 2011 UTC (8 years, 7 months ago) by overbeek
minor fix
Fri Jul 15 01:31:50 2011 UTC (8 years, 7 months ago) by overbeek
put loc in seq hdrs for prot alignments
Fri Jul 15 01:24:24 2011 UTC (8 years, 7 months ago) by overbeek
Fri Jul 15 01:13:03 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.10: +6 -4 lines
put out contigs
Thu Jun 30 22:18:21 2011 UTC (8 years, 7 months ago) by overbeek
put tbl and fasta in snp directory
Thu Jun 30 17:08:49 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.8: +11 -4 lines
connections to alignments is better
Wed Jun 29 20:57:45 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.7: +77 -40 lines
build snp features
Wed Jun 29 15:07:57 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.6: +1 -0 lines
unlink temporary file
Wed Jun 29 15:05:16 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.5: +8 -22 lines
faster SNP detection, reduced set of alignments, and html of the SNP alignments
Tue Jun 28 23:16:27 2011 UTC (8 years, 7 months ago) by overbeek
avoid -z option
Tue Jun 28 20:57:09 2011 UTC (8 years, 7 months ago) by overbeek
allow white space rather than just tab
Tue Jun 28 17:47:00 2011 UTC (8 years, 7 months ago) by overbeek
Changes since 1.2: +35 -24 lines
parallelize
Mon Jun 27 17:13:58 2011 UTC (8 years, 8 months ago) by overbeek
CVS Tags: myrast_rel40
Changes since 1.1: +3 -0 lines
make part of myRAST distribution
Mon Jun 27 17:05:45 2011 UTC (8 years, 8 months ago) by overbeek
build alignments and SNPs for very close strains
