[Bio] / FigKernelPackages / tree_utilities.pm Repository:
Log of /FigKernelPackages/tree_utilities.pm
Thu Apr 17 18:32:52 2008 UTC (11 years, 10 months ago) by disz
Changes since 1.16: +8 -2 lines
Diff to previous 1.16
added subsyste display on hover
Tue Mar 25 17:32:42 2008 UTC (11 years, 11 months ago) by disz
Changes since 1.15: +80 -1 lines
Additions for JAVA tree based annotation
Fri Mar 7 17:06:25 2008 UTC (11 years, 11 months ago) by overbeek
Changes since 1.14: +14 -0 lines
try to point to the old FigfamsData
Fri Sep 7 19:35:17 2007 UTC (12 years, 5 months ago) by overbeek
fixes to labels with quotes
Sun Feb 4 13:02:33 2007 UTC (13 years ago) by parrello
Fixed a compiler warning.
Thu Feb 1 14:58:06 2007 UTC (13 years ago) by overbeek
Changes since 1.11: +5 -4 lines
strip comments on functions for subsystem checking
Mon Jan 29 18:59:08 2007 UTC (13 years ago) by overbeek
Changes since 1.10: +14 -1 lines
debugged version of bring_tree_up_to_ali
Thu Jan 11 19:59:54 2007 UTC (13 years, 1 month ago) by overbeek
delete temp directories in phylogeny tools
Sat Jan 6 17:39:41 2007 UTC (13 years, 1 month ago) by overbeek
make sure tree insertion code is all committed
Thu Dec 21 21:36:03 2006 UTC (13 years, 2 months ago) by overbeek
handle labels in newick trees
Thu Dec 21 21:11:28 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.6: +2 -1 lines
fixes to writing newick trees and a program to evaluate trees
Mon Dec 4 19:18:26 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.5: +38 -28 lines
fixes to representative tree generation and added rep_genomes
Added license words.
Wed Jan 5 20:24:14 2005 UTC (15 years, 1 month ago) by overbeek
Changes since 1.3: +5 -5 lines
minor fixes to subsys.cgi and tree_utilities.pm
Thu Dec 30 02:30:16 2004 UTC (15 years, 1 month ago) by overbeek
add tree manipulation utilities
Thu Jan 29 11:48:30 2004 UTC (16 years ago) by overbeek
Changes since 1.1: +36 -1 lines
fix bug in display_tree
Mon Dec 1 16:54:26 2003 UTC (16 years, 2 months ago) by efrank
Branch point for: initial
