[Bio] / FigKernelPackages / selenoprotein_ref_seq.pm Repository:
Log of /FigKernelPackages/selenoprotein_ref_seq.pm
Sat Mar 29 05:19:01 2008 UTC (12 years ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.3: +10 -0 lines
Add to the list of reference proteins.
Thu Dec 6 01:41:57 2007 UTC (12 years, 4 months ago) by golsen
Changes since 1.2: +109 -86 lines
Add functions to reference selenoproteins, and add change the set
slightly.  Report function of best matching protein.  Optionally
report the id of the best matching protein.
Thu Nov 22 00:07:28 2007 UTC (12 years, 4 months ago) by golsen
Changes since 1.1: +14 -7 lines
Slight improvement to the list of reference selenoproteins.
Wed Nov 21 22:24:38 2007 UTC (12 years, 4 months ago) by golsen
This file contains a reference set of selenoproteins for use by
find_selenoproteins.
