[Bio] / FigKernelPackages / representative_sequences.pm Repository:
Log of /FigKernelPackages/representative_sequences.pm
Sat May 12 21:22:23 2007 UTC (12 years, 10 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.8: +2 -0 lines
add make_trimmed_alignment_from_ids
Sat May 12 20:47:03 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.7: +27 -3 lines
Modifications to control ordering of sequences in representative sets and
in sequeneces added to an alignment.  Also new options to silently remove
sequences with duplicate ids.
Sat May 12 20:12:56 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.6: +66 -1 lines
add utilities for computing alignments
Mon Mar 19 20:01:56 2007 UTC (13 years ago) by golsen
Fix to error message.
Mon Mar 19 18:58:10 2007 UTC (13 years ago) by golsen
Changes since 1.4: +667 -318 lines
Change in the representative sequences algorithm.  This could still use
more work.
Wed Feb 28 21:55:44 2007 UTC (13 years, 1 month ago) by overbeek
Changes since 1.3: +0 -1 lines
remove debugging line from representative_sequences.pm
Mon Feb 19 14:43:57 2007 UTC (13 years, 1 month ago) by overbeek
Changes since 1.2: +6 -3 lines
update PHOB.pm
Fri Feb 16 17:41:34 2007 UTC (13 years, 1 month ago) by golsen
Changes since 1.1: +48 -14 lines
Major improvement in representative_sequences.pl.  Greatly improved
comments in representative_sequences.pm.
Wed Dec 20 20:49:21 2006 UTC (13 years, 3 months ago) by golsen
Adding representative_sequences.pm
