[Bio] / FigKernelPackages / raelib.pm Repository:
Log of /FigKernelPackages/raelib.pm
Links to merge-bobdev_news-2: (view) (download) (as text) (annotate)
Fri Jun 10 16:43:27 2005 UTC (14 years, 8 months ago) by redwards
Diff to previous 1.19
minor changes to pir.cgi
Fri Jun 10 16:12:53 2005 UTC (14 years, 8 months ago) by redwards
Diff to previous 1.18
updating raelib
Fri Jun 10 15:36:37 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.17: +82 -11 lines
Diff to previous 1.17
adding correspondence.cgi
Thu May 26 18:15:59 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.16: +150 -0 lines
Diff to previous 1.16
Added GenBank method to raelib.pm
Wed May 25 00:49:39 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.15: +3 -0 lines
minor changes to uniprot correspondence
Tue May 24 23:53:24 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.14: +3 -3 lines
Tue May 24 22:57:19 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.13: +62 -16 lines
added uniprot knowledge base to load_pirsf and raelib
Wed May 4 03:07:23 2005 UTC (14 years, 9 months ago) by parrello
Sat Apr 9 17:21:15 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.11: +12 -0 lines
changes to seed_ctl and raelib
Fri Apr 8 20:22:23 2005 UTC (14 years, 10 months ago) by redwards
changed tag/value pairs completely. Ooops!
Thu Apr 7 19:16:10 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.9: +4 -1 lines
many changes to key/value pairs to make them work
Sun Apr 3 19:25:21 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.8: +12 -2 lines
changes to pir interactions
Sun Apr 3 19:11:11 2005 UTC (14 years, 10 months ago) by redwards
Added a script to load pir superfamilies in the background. This will download all the data and install it. Changed pir.cgi to background this job as it takes a while.
Sun Apr 3 02:15:15 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.6: +4 -4 lines
changes to pir-seed interactions and new help page
Sun Mar 20 00:08:39 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.5: +5 -4 lines
changes to organisms.cgi to bring in my seed
Sat Mar 19 17:45:47 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.4: +152 -0 lines
added rae.cgi, a FigWebServices page with a bunch of crap I wrote.
Fri Feb 11 21:26:25 2005 UTC (15 years ago) by redwards
Changes since 1.3: +40 -0 lines
Additions to raelib
Wed Feb 2 01:07:44 2005 UTC (15 years ago) by redwards
Changes since 1.2: +62 -1 lines
Minor changes to ubsys.cgi  (mainly commenting) and raelib adding tagvalue
Mon Jan 31 16:58:38 2005 UTC (15 years ago) by redwards
Minor change to raelib to correctly get the correspondance between uniprot/pir and seed/sprout
Sat Jan 29 20:58:48 2005 UTC (15 years ago) by redwards
Added raelib.pm, a bunch of stuff I am using myself. Does not come with a freshness guarantee. Use at own risk.
