[Bio] / FigKernelPackages / raelib.pm Repository:
Log of /FigKernelPackages/raelib.pm
Fri May 3 17:21:26 2013 UTC (6 years, 7 months ago) by redwards
Changes since 1.46: +1 -1 lines
Diff to previous 1.46
adding phage stuff
Fri May 27 19:14:40 2011 UTC (8 years, 6 months ago) by redwards
CVS Tags: mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928
Changes since 1.45: +1 -0 lines
Diff to previous 1.45
adding unzip
Fri Jan 21 20:35:02 2011 UTC (8 years, 10 months ago) by redwards
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.44: +29 -0 lines
Diff to previous 1.44
adding a pegs in order method (should probably be in FIG.pm cos way useful)
Sun Mar 16 18:24:57 2008 UTC (11 years, 8 months ago) by redwards
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_release_2008_09_29
Changes since 1.43: +15 -0 lines
Diff to previous 1.43
adding a randomizer function
Tue Feb 5 02:05:47 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.42: +30 -28 lines
Diff to previous 1.42
Changed POD heading levels.
Sun Jan 14 18:15:43 2007 UTC (12 years, 10 months ago) by redwards
Changes since 1.41: +1 -1 lines
Diff to previous 1.41
fixing a warning error
Tue Oct 10 00:51:40 2006 UTC (13 years, 1 month ago) by redwards
Changes since 1.40: +2 -2 lines
Diff to previous 1.40
redirecting Spreadsheet::WriteExcel
Wed Jul 19 21:57:47 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.39: +7 -3 lines
Diff to previous 1.39
REA: Getting rid of crytptic error message
Tue Jun 20 03:34:43 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.38: +64 -23 lines
Diff to previous 1.38
RAE: Updating table writing in excel to deal with merged cells
Mon Jun 19 21:19:22 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.37: +54 -31 lines
Diff to previous 1.37
RAE: Simplifying making excel tables
Mon Jun 19 04:05:21 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.36: +16 -0 lines
Diff to previous 1.36
RAE: updating the excel functions
Wed Jun 14 01:14:19 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.35: +7 -1 lines
Diff to previous 1.35
RAE: Adding excel files to display_subsys
Tue Jun 6 02:25:37 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.34: +9 -2 lines
Diff to previous 1.34
RAE: adding more to heatmap, and removing the contigs for environmental samples
Tue Jun 6 00:58:23 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.33: +41 -2 lines
Diff to previous 1.33
RAE: Initial release of a new interface that plots a heatmap of proteins that are in subsystems. The initial release is just based on a single attribute (ss_connections), but I hope to extend it to mapping on different things. Makes pretty tables though!
Wed May 10 15:47:57 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.32: +2 -2 lines
Diff to previous 1.32
RAE: adding new excel functions
Sun May 7 20:10:07 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.31: +138 -50 lines
Diff to previous 1.31
RAE: Updating excel writing functions
Sat May 6 22:04:12 2006 UTC (13 years, 7 months ago) by overbeek
Changes since 1.30: +219 -0 lines
Diff to previous 1.30
RAE: Adding writing excel tables to raelib, html, and initial trial in select.cgi
Fri Feb 10 00:39:30 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.29: +22 -0 lines
Diff to previous 1.29
RAE: Updating organisms.cgi for more information per organim
Sun Feb 5 01:08:16 2006 UTC (13 years, 10 months ago) by overbeek
Diff to previous 1.28
RAE: Swtiched to using SQL Count for the number of contigs
Changes since 1.27: +17 -0 lines
Diff to previous 1.27
Added license words.
Mon Oct 3 20:05:34 2005 UTC (14 years, 2 months ago) by redwards
Changes since 1.26: +49 -2 lines
Diff to previous 1.26
Initial release of cookies code, including myseed
Fri Aug 5 16:22:53 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.25: +1 -1 lines
Diff to previous 1.25
subsystems by homology really by homology
Fri Aug 5 15:37:14 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
minor change to add empty fast records
Thu Aug 4 22:35:28 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.23: +5 -2 lines
Diff to previous 1.23
Counting subsystems
Mon Jul 11 21:25:03 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.22: +46 -0 lines
Diff to previous 1.22
changing raedraw and raelib
Sun Jul 10 22:48:23 2005 UTC (14 years, 4 months ago) by redwards
Changes since 1.21: +1 -1 lines
Diff to previous 1.21
sorting scrolling subsystem list
Sat Jul 9 19:59:23 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.20: +43 -1 lines
Diff to previous 1.20
Initial release of subsys_vectors.cgi
Fri Jun 10 16:43:27 2005 UTC (14 years, 5 months ago) by redwards
Diff to previous 1.19
minor changes to pir.cgi
Fri Jun 10 16:12:53 2005 UTC (14 years, 5 months ago) by redwards
Diff to previous 1.18
updating raelib
Fri Jun 10 15:36:37 2005 UTC (14 years, 5 months ago) by redwards
Changes since 1.17: +82 -11 lines
Diff to previous 1.17
adding correspondence.cgi
Thu May 26 18:15:59 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.16: +150 -0 lines
Diff to previous 1.16
Added GenBank method to raelib.pm
Wed May 25 00:49:39 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.15: +3 -0 lines
minor changes to uniprot correspondence
Tue May 24 23:53:24 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.14: +3 -3 lines
Tue May 24 22:57:19 2005 UTC (14 years, 6 months ago) by redwards
Changes since 1.13: +62 -16 lines
added uniprot knowledge base to load_pirsf and raelib
Wed May 4 03:07:23 2005 UTC (14 years, 7 months ago) by parrello
Sat Apr 9 17:21:15 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.11: +12 -0 lines
changes to seed_ctl and raelib
Fri Apr 8 20:22:23 2005 UTC (14 years, 8 months ago) by redwards
changed tag/value pairs completely. Ooops!
Thu Apr 7 19:16:10 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.9: +4 -1 lines
many changes to key/value pairs to make them work
Sun Apr 3 19:25:21 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.8: +12 -2 lines
changes to pir interactions
Sun Apr 3 19:11:11 2005 UTC (14 years, 8 months ago) by redwards
Added a script to load pir superfamilies in the background. This will download all the data and install it. Changed pir.cgi to background this job as it takes a while.
Sun Apr 3 02:15:15 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.6: +4 -4 lines
changes to pir-seed interactions and new help page
Sun Mar 20 00:08:39 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.5: +5 -4 lines
changes to organisms.cgi to bring in my seed
Sat Mar 19 17:45:47 2005 UTC (14 years, 8 months ago) by redwards
Changes since 1.4: +152 -0 lines
added rae.cgi, a FigWebServices page with a bunch of crap I wrote.
Fri Feb 11 21:26:25 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.3: +40 -0 lines
Additions to raelib
Wed Feb 2 01:07:44 2005 UTC (14 years, 10 months ago) by redwards
Changes since 1.2: +62 -1 lines
Minor changes to ubsys.cgi  (mainly commenting) and raelib adding tagvalue
Mon Jan 31 16:58:38 2005 UTC (14 years, 10 months ago) by redwards
Minor change to raelib to correctly get the correspondance between uniprot/pir and seed/sprout
Sat Jan 29 20:58:48 2005 UTC (14 years, 10 months ago) by redwards
Added raelib.pm, a bunch of stuff I am using myself. Does not come with a freshness guarantee. Use at own risk.
